Axle oil seals.
Holland
Dave Wind 66 White
Which way do the axle oil seals on the transmission face, spring in towards the transmission, or out. Thanks
Holland
1966 white
CapnJohn
Holland
1966 white
Those should be a double lip seal (Hugh Gordon has them) with a spring on each side. One facing in to keep oil in, and the other facing out to keep water out.
Holland
Dave Wind 66 White
body{font-family: Geneva,Arial,Helvetica,sans-serif;font-size:9pt;background-color: #ffffff;color: black;}
Thanks John, I forgot that there is a spring on each side.
Holland
-----Original Message----- From: CapnJohn Sent: Sep 13, 2008 7:19 PM To: dhwind@earthlink.net Subject: RE: [General Amphicar Discussion-t-20169] Re: Axle oil seals.
Quote:
Originally Posted by Holland
Which way do the axle oil seals on the transmission face, spring in towards the transmission, or out. ThanksHolland1966 whiteThose sould be a double lip seal with a spring on each side. One facing in to keep oil in, and the other facing out to keep water out.
S Front Axle Oil Seals General Amphicar Discussion 2
Jon March Axle tube bushings - a followup question... General Amphicar Discussion 0
LSolheim Axle Weights General Amphicar Discussion 3
Jacques B. Amphicar Axle shaft removal from the gearbox General Amphicar Discussion 5
cigarman Axle Tunnel repair (welded in wrong) General Amphicar Discussion 4
Midwest Amphicar getting ready for some axle suck in Sabula General Amphicar Discussion 0
T Axle Zerk Fitting??? General Amphicar Discussion 3
T Axle u-joints General Amphicar Discussion 3
Midwest Amphicar Axle install General Amphicar Discussion 9
C RUBBER AXLE CAPS !!! General Amphicar Discussion 24
J AXLE CAPS !!! General Amphicar Discussion 0
D axle suck soon very soon General Amphicar Discussion 0
A Axle tunnel repair General Amphicar Discussion 0
B Rear Swing Axle Needed General Amphicar Discussion 1
R double axle trailer General Amphicar Discussion 1
T Shocks, axle boots General Amphicar Discussion 1
G Axle question General Amphicar Discussion 9
G rear axle. General Amphicar Discussion 1
C Rear Axle rebuilding General Amphicar Discussion 1
A REMOVING AXLE HOUSING WITH AXLE General Amphicar Discussion 1
K Axle sliipiing out of tranny General Amphicar Discussion 0
D axle- river General Amphicar Discussion 0
D help with axle idea ---- Great book General Amphicar Discussion 2
C Axle shaft removal General Amphicar Discussion 4
C rear axle boot General Amphicar Discussion 4
E Axle Tube Greasing General Amphicar Discussion 0
E Rear Axle Spline Compression Springs General Amphicar Discussion 2
E Axle Nut & Washer Sequence General Amphicar Discussion 0
E Axle Nut Torque General Amphicar Discussion 0
D Rear Axle Tunnel To Tranny Boots General Amphicar Discussion 3
W TIP; Split axle reassembly. General Amphicar Discussion 0
E Rear Axle Design General Amphicar Discussion 1
R single axle General Amphicar Discussion 0
R Axle success General Amphicar Discussion 0
A trouble with axle General Amphicar Discussion 0
