anyone have this rear hub tool?
Jon March
my hubs have noisy bearings, even tho they were just done with all new bearings and seals! One of then was done twice because of growling with new bearings after first install. Still not right - you can feel bumps and imperfections when you turn it (and you can really hear it holding your ear against the arm-end) There is either contamination in the bearings or they got damaged being installed.,...so, im gonna try this myself this time.
1) first, is it ok to use a "block of wood and a mallet" to drive the shaft-end out of the hub?
I know there is a c-clip holding the outer seal in, as well as washers/spacers that i need to "mind" how they go back in..
My goal is to clean the blue Amsoil grease out of the bearings (with carb cleaner?), then check them for issues and replace as needed
But i dont know anyone near me who has the recommended tool that Jeff Collins in Ontario made up to pull the tapered end fully into the hub. I asked Gordons, and they said they never use the tool, that the castle nut does a fine job pulling it in completely. But with John Bevins, Ron Green, Gord, Dave, etc all very adamant about the pulling - tool - Im lost as to what to do - conflicting info and this is the 3rd re-do on these things and i want them done right!#$ The first place that did them was 2 hours drive one way. thes should turn SMOOTH as velvet - and they both still have issues.
Do i take them to a machine shop for 50/hour?
Will they have the tool? - And Im unclear - whats so different about this tool that its better than a nice strong nut (maybe not a castle nut, but a hardened one - People seem to warn that the threads on the shaft will de-form if you use a nut to do the "pull", but doesnt this tool just use the same threads to pull the shaft thru till it seats?
http://www.midwestamphicar.com/images/axle8.JPG
jm
mschlem
I've just done this job.....
The shaft wasn't overly tight in the bearing ID's, so it drove out pretty easy with a block of wood and a mallet. Likewise, it went in through the new bearings nice. I used a block of wood on one side of the yoke and lightly tapped the shaft into place. No major beating was required going out or in....just nice solid tapping.
The bigger deal is getting the hub off BEFORE trying to drive the shaft out. I'm sure you've seen mention of this on Dave's web page since you had the image of the tool included in your post. He has some good info about this job. Hopefully your hub will come off since it has just been off recently. (I echo Dave's suggestion to get a box of disposable gloves!)
Seems like a good time to throw this one out there for someone......how tight should the castle nut be? As tight as possible? Is there a torque rating?
Marc.
Hi Jon,
I second what Marc said and drove my shafts into the bearing by just tapping the yokes. No huge hanging required. Just check to be sure the shaft is all the way seated into the bearings. As he said, the real problem is getting the hubs off of the shafts. A very heavy duty puller is required and keep the castle nut threaded down to protect the end of the shaft from getting wrecked by the puller and sledge banging that is usually required to get the hubs off.
Jon March
yes - the hubs were removed long ago - the driver rear needed a puller.... the passenger one that had key-play in it came off by hand
Jon March
So, getting the bearings our of the hub - just gently tap on one side, then the other till they eventually "work" out"?
And ive seen bearings put back IN the hubs with a shop-press, which i would think would cause less damage/impact to the bearings than the original method; a metal disc on a shaft that was hammered(however gently) into place
John Howland Can anyone tell me the diameter of the air hose ro air cleaner General Amphicar Discussion 2
Jon March Anyone know who ended up buying this Amphi? General Amphicar Discussion 1
Jon March anyone know whose car this is? General Amphicar Discussion 3
Jon March Anyone have a new one of these I can buy? General Amphicar Discussion 0
scottamphi Does anyone use circuit breakers? General Amphicar Discussion 10
Cameron in UK Anyone know the source of this New York Amphi photo ? General Amphicar Discussion 6
C Can anyone share their experiences with Gordon Imports Body mouldings General Amphicar Discussion 18
C Has anyone had problems with Pertronix coils? General Amphicar Discussion 6
Midwest Amphicar Anyone up for this? General Amphicar Discussion 0
Akamphi Anyone making Amphicar tools? General Amphicar Discussion 1
mike_israel Is anyone having trouble posting pictures? General Amphicar Discussion 3
inaintheboro Does this guy look familiar to anyone? General Amphicar Discussion 1
Tom Laferriere Anyone in UK near Beaumont Shopping Centre, Leicester City? General Amphicar Discussion 1
DavidC Anyone fancy a Triphibian General Amphicar Discussion 1
C Does anyone know who has a steering box sealing boot? General Amphicar Discussion 0
C Fwd: Anyone near Lancashire, UK who could help with transport to the port for... General Amphicar Discussion 1
B Water Injection, Anyone? General Amphicar Discussion 5
M Anyone Heading East or Needing to Tow East?? General Amphicar Discussion 0
R No Celina photo yet - anyone else still waiting? General Amphicar Discussion 0
A Anyone near Richmand. VA... General Amphicar Discussion 2
C Really want one!!! Anyone know anything this cute amphi on Ebay # 4566799699 General Amphicar Discussion 2
F anyone else heard of this General Amphicar Discussion 3
J Message posted for Rob Vondracek - Anyone want parts delivered to Mt Dora General Amphicar Discussion 0
A Scheduled Swim-Ins Anyone? General Amphicar Discussion 0
A Anyone care to comment... General Amphicar Discussion 3
C Can anyone help me? General Amphicar Discussion 4
M Anyone in Celina? General Amphicar Discussion 0
M Anyone in Celina?? General Amphicar Discussion 0
A Anyone near ESCONDIDO, Ca? General Amphicar Discussion 0
M Cheap Amphicars Anyone General Amphicar Discussion 3
M Amphi on Ebay in AZ - Anyone know anything about it? General Amphicar Discussion 0
M Anyone Near Chattanooga, TN? (No Amphi COntent) General Amphicar Discussion 0
A (off topic) Anyone near Bismark ND? I need a truck inspected General Amphicar Discussion 0
A Anyone near Livingston Texas? General Amphicar Discussion 2
A Anyone travelling from Georgia up North or out west? General Amphicar Discussion 0
M Cheap Amphicar Anyone General Amphicar Discussion 0
D Anyone planning a trip to London ? ... General Amphicar Discussion 1
C Anyone in the Houston Area? General Amphicar Discussion 0
C Anyone want to trade an Amphi for my RV? General Amphicar Discussion 0
J Anyone familiar with Sahli Enterprises of Newport Beach? General Amphicar Discussion 0
M Anyone Near Odessa, FL (Off Topic) General Amphicar Discussion 0
M Anyone want a Schimmwagen 166 General Amphicar Discussion 0
J Calling Victor Brown!!! (Or anyone who can get a hold of him) General Amphicar Discussion 0
