Hey Jack
I*had the same question- but it seems that forward is the only way it will work
Will you make it*in August*for Taunton swimin?***** I have a few good weeks of work left - currently its running with just exterior paint and trim to go.*** Hope to see you there****
To: dwoods164@yahoo.com
Sent: Sunday, July 12, 2009 11:35:38 AM
Subject: [General Amphicar Discussion-t-20479] Angle water shift is mounted?
It sounds like a simple question, but I have seen the water shifts mounted in both directions??? It can be mounted so it is angled forward in neutral but looks like it will interfere with the floorboard when pushed forward. OR, so it is almost verticle in neutral but might hit the seat when pulled back into reverse! Thanks, Jack
