Jack,
As promised, I had a chance to talk with Stephanie, the Dealer Relations
gal at AMSOIL, and first off, you should be using Customer Number 508472
(not ...972, as you give below). Then your two choices are either: 1.)
create a "Preferred Customer" account (for a 10% discount, which may
make sense if it's a largish $200+ order, or if you think you might make
a second or more orders that year totalling more that $200), or, 2.)
Just buy the stuff you need at the regular catalog price. Amphicar.net
will get its little referral fee to keep the lights on whatever option
you may choose
Drop me a line if you have any more problems. With a little luck, I
will get around to updating the "AMSOIL for Amphicars Catalog" this
Summer.
Regards,
Bilgey
On Tue, 19 May 2009 11:40 am, Bilgemaster wrote:
> Thanks for the tip. I'll have to give AMSOIL a call and straighten that
> out. Tatiana's the wife, which I did for tax reasons.
> Regards,
> Bilgey
> On Tue, 19 May 2009 10:36 am, canitfloat wrote:
> Quote:
>> FYI, I just called Amsoil at 1-800-956-5695 to place an order for
>> grease and gear lube. I was told the cust # 508972 could only be used
>> by the person it belongs to (Tatiana) and I would have to setup my own
>> account which I did, however I was told they gave me a club discount
>> by
>> mentioning the IAOC. Also the number AGM-1G for the gallon of gear
>> lube
>> is no longer good. It is now called marine gear lube and only sold by
>> the qt. @$7.40 /qt The grease has the same number. Determined to be
>> floating this summer...Jack
