Triumph originally used a bellows type thermostat, this allowed space on top for sensor. The bellows thermostat is OK but not very accurate and if it fails it fails shut so engine overheats.
Mid 60s they changed to a wax thermostat. Simpler and cheaper, should be more reliable but importantly it fails open. Downside is there is no clearance for sensor on top. Triumph moved sensor to side of water pump housing to fix this.
So, options are find an original thermostat (now rare) use a later Triumph pump housing (rare in US but what everyone would do in Euro Land) or use some sort of spacer - never done that so don't know how well it would work or if it might cause other probs.
David C
(first email post to new list)
To:
DavidC
Sent: Thursday, January 03, 2008 8:29 PM
Subject: [General Amphicar Discussion-t-4600] Amphicar Thermostats?
Just what is the correct thermostat for these? I bought one the other day for a Triumph 1147 thinking it'd fit and be the right one. However it dosn't fit. It seems to tall. I noticed that Gord Souter sells a Thermostat kit New style new spacer. Is this what people are using. If not what one works with the stock motor?
