> Hello,
> The opening and shaft spacing in the Amphicar is for what was called
> a "mini Euro" size opening. It's the same size as the opening in
> Volkswagen bugs of the 60's. During the early 70's, the Japanese
> made a number of radios designed to be aftermarket replacements for
> the VW radios. These radios are a perfect fit, though most of them
> are negative ground and stereo. I use such radios in my cars but my
> cars are converted to negative ground. I also use old Alpine booster
> amps in my cars and 5 x 7" speakers mounted under the dashboard. The
> stereo separation is marginal but the sound is good and can even be
> heard at freeway speeds with the top down. I found mine on Ebay.
> Mine are AM/FM stereo with a period correct dial scale and 5 push
> buttons. I also found them that look the same but have an auto
> reversing cassette deck in them. The dial glass folds back when you
> insert the tape. Generally, I use a small MP3 player and small
> transmitter to broadcast the tunes to the FM radio. I simply load up
> all the tunes I like in my player and hand both of them from the
> rear view mirror while playing. All of these things are available on
> Ebay but the old radios can be a bit scarce.
> Regards,
> John Friese
> Hello,
> Regards,
> John Friese
> Hello,
> Regards,
> John Friese
> Hello,
> Regards,
> John Friese
