Amphicar Nightmare Update / Clutch Problem in First Gear
P
portlandamphicar
Hello Everyone!
Just an update on my Amphicar -- the one that was damaged by the
moving company during transport from Florida to Portland. I'm happy
to report that after a month in the shop (and several thousand
dollars later -- all paid by the moving company), everything looks
great. I was finally able to take it for my first drive this morning.
That brings a question: When I took it out for a spin, there was a
terrible rattling and shaking when I was in first gear. The shaking
is so bad that if you don't hold the gear stick hard, it will pop
into neutral. Once it gets into second, third, and fourth,
everything is nice and smooth.
Does anyone know what may be happening? It sounds like a clutch
problem to me, but I was wondering if this is common with Amphicars.
Should I take it to a transmission specialist?
Also, I can't find the VIN plate on the Amphicar. Where are these
normally located? I need to transfer the title over.
Thanks for your help!
Charles
'67 Red
Hello Charles,
Glad to hear your Amphicar survived (kind of) the fall from the
truck.
The chatter that you have (and boy does yours sound bad) is from the
clutch. Amphicars were built with an old style spring clutch that is
very finicky and the rebuilt clutch disks rarely work smoothly. Look
into the Amphicar site classifieds to see a high performance clutch
replacement package that I just started to sell. It replaces the old
style clutch with a later, diaphragm type clutch. I've used mine for
several thousand miles and it works fine.
The VIN plate should be on the wall of the engine compartment just
above and to the left of the coil. The VIN number is also stamped on
the top of the right hand frame rail, just ahead of the radiator
support bracket. Those numbers were often coated with paint and you
may have to sand that paint off to see them. It's a good idea to
spray several coats of clear paint over them, for protection, if you
sand down to the metal.
White 67
Red 67
--- In amphicar-lovers@yahoogroups.com, "portlandamphicar"
<portlandamphicar@y...> wrote:
> Hello Everyone!
happy
morning.
shaking
Amphicars.
> Charles
> '67 Red
> a terrible rattling and shaking when I was in first gear.
Charles,
The clutch's pressure plate is your problem. To avoid the (very
common) cha...cha...chatter for the time being, start out in 2nd
gear while on the road. It will not harm the car at all. First gear
is mainly for exiting waterways anyway. The pressure plate needs
adjusting. This needs to be done by a clutch expert with experience
with these types of clutchs. It will need to be removed from the car
for adjustment which is not that big of a deal, just time consuming.
I have pictures of all the locations where to look for the VIN if
your tag is gone. Bilgy gave the VIN info a page at
http://www.amphicar.com/vin_numbers.htm. Take a peek! I was
surprised to see my VIN stamped in the engine cover and the hood. I
have still not seen this on any other car.
John Bevins
Rocky Mountain Amphicar
P Amphicar Transport Nightmare General Amphicar Discussion 4
J 1967 Amphicar Tub Toy Restorations in progress 3
mike_israel The only car I consider to be way cooler than the Amphicar General Amphicar Discussion 2
T Parting ways with my 64 Amphicar General Amphicar Discussion 0
AmazingOne Restored 1964 Amphicar for sale General Amphicar Discussion 0
chapron67 Wanted to buy: Nice, useable Amphicar. General Amphicar Discussion 3
mike_israel Annual costs of maintaining an Amphicar (Forum) ... General Amphicar Discussion 10
Jon March lot #012 - The next big Amphicar auction: end of This week! - lot #012 General Amphicar Discussion 4
strandweiss62 RHD Amphicar sold at Mecum General Amphicar Discussion 2
C Amphicar with Buick V6! General Amphicar Discussion 4
DavidC Amphicar club gift. General Amphicar Discussion 3
Andreas Gomoll „The Uganda-Amphicar“ - Brakeparts needed... General Amphicar Discussion 0
Andreas Gomoll ... my Amphicar has some specials.... Restorations in progress 2
B Amphicar Tow Bar General Amphicar Discussion 0
B Celina Amphicar Record General Amphicar Discussion 3
T Amphicar Furniture General Amphicar Discussion 6
mike_israel Amphicar Hawaiian Shirts - Order Deadline Approaching General Amphicar Discussion 0
Jon March the 3 different Amphicar factory driveshafts General Amphicar Discussion 2
sdreich Amphicar Transmissions General Amphicar Discussion 12
L long distance moves for Amphicar General Amphicar Discussion 6
sdreich Amphicar Hubcaps on eBay and More General Amphicar Discussion 4
LSolheim 2018 Clearlake Seaplane - Amphicar: Fly & Swim-in General Amphicar Discussion 0
Jon March Amphicar chase-scenes General Amphicar Discussion 0
Midwest Amphicar Central Florida Amphicar Swim In General Amphicar Discussion 4
Jon March GREAT Amphicar footage from the hot new Northeast "Naples Swim" General Amphicar Discussion 0
scottamphi What Pertronix Fit My Amphicar General Amphicar Discussion 6
mike_israel Merry Christmas & Joy to the Amphicar World General Amphicar Discussion 1
BlueFin Scam Amphicar Ad General Amphicar Discussion 11
mike_israel New Amphicar Children's Book General Amphicar Discussion 4
mike_israel Amphicar on Jay Leno's Garage General Amphicar Discussion 9
B Amphicar Fuses?? General Amphicar Discussion 2
Jon March Sun June 7 - "worlds fair edition" Amphicar?! General Amphicar Discussion 2
mike_israel New Walt Disney World Restaurant Offers Amphicar Rides General Amphicar Discussion 42
mike_israel Do you think this part will fit an Amphicar General Amphicar Discussion 2
dutchamphi Inspector Clouseau-Amphicar episode 1968 General Amphicar Discussion 6
auburnamphi Amphicar Owners In Georgia General Amphicar Discussion 2
C Amphicar article in Maine Magazine General Amphicar Discussion 1
