Amphicar Jack
Holland
Dave Wind 66 White
I have a 1966 Amphicar. Under the gas tank there is a square tube welded to the floor. It is the same size as the square jack tubes on the outside. The arm of the Bilstien jack fits in perfectly. Is that the correct place to store the jack, or what is the square tube for?
Also, the Bilstien jack is not long enough to raise the car. It appears to be the original jack. Any suggestions.
Thanks, Dave Wind
Tedredamphi
That's where the jack is stored. Here's a picture that CapnJohn sent me recently. My jack is just over 22 inches tall and lifts the Amphicar. Similar jacks of different heights were used on other model cars of the time.
Ted
azpaul50
Just out of curiosity, has anyone used one of those airbag lifts they sell for Nash Metropolitans? The Met has the same mid-body jack point and is very similar for jacking. This is an airbag that lifts the entire side of the car. You plug the bag's hose into the tail pipe and fill the bag with the motor running and exhaust fumes. I saw one once at a Unique Little Car Show in Long Beach and it works pretty good but takes a while to fill with a 4-cylinder. Just a thought although the Amphi pipe is a big larger than the Met's. They sell them through the Met Pit Stop last I saw. - azpaul
To: azpaul50@hotmail.comSubject: RE: [General Amphicar Discussion-t-20289] Re: Amphicar JackDate: Sat, 10 Jan 2009 18:42:10 -0500From:
That's where the jack is stored. Here's a picture that CapnJohn sent me recently. My jack is just over 22 inches tall and lifts the Amphicar. Similar jacks of different heights were used on other model cars of the time.TedAttached to this message is trunk_2_16_02.jpg
Windows Live™: Keep your life in sync.
http://windowslive.com/explore?ocid=TXT_TAGLM_WL_t1_allup_explore_012009
DavidC
The theory of those is the weight is spread evenly but in Amphicar the one I
tried tended to push on the floor either side of the frame rails and bend
it.
Another reason I don't like them is safety issues - mechanical jacks
normally give some warning but when those fail it's like a ballon popping
and the car is on the ground within a second - no jump out of the way time.
Best tip for jacking is mark with white paint the 6 Amphicar jacking points,
these are directly under the frame rails, 3 each side, front back and
centre. The centre (about level with the door handle) is the balance point
that allows you to lift one side of the car.
David C
LSolheim
Interesting. My jack is stored in clamps mounted to the back side of the
12-49-12 Trunk Insert, against the front of fuel tank, Although that square
tube is in there.
--Larry
Sent: Saturday, January 10, 2009 3:42 PM
To: lrsnpark@gmail.com
time.
Ted
<http://www.amphicar770.com/amphicarforum/attachments/general-amphicar-discu
ssion/289d1231630683-amphicar-jack-trunk_2_16_02.jpg>
Larry,
Both of my cars have the storage on the back of that trunk board and one of them has the pipe welded to the floor too. I use the floor mount in the car that has it and the trunk board in the one without the pipe. I asked Hugh about this once and I think he said the mount on the back of the board was frowned on because in a front end crash the jack would get pushed into the gas tank. Strange though since my very late car is the one without the floor mounting pipe.
67 White (not so late)
67 Red (very late)
mike_israel 2021 Amphicar Photos Contest General Amphicar Discussion 14
J 1967 Amphicar Tub Toy Restorations in progress 3
mike_israel The only car I consider to be way cooler than the Amphicar General Amphicar Discussion 2
T Parting ways with my 64 Amphicar General Amphicar Discussion 0
AmazingOne Restored 1964 Amphicar for sale General Amphicar Discussion 0
chapron67 Wanted to buy: Nice, useable Amphicar. General Amphicar Discussion 3
mike_israel Annual costs of maintaining an Amphicar (Forum) ... General Amphicar Discussion 10
Jon March lot #012 - The next big Amphicar auction: end of This week! - lot #012 General Amphicar Discussion 4
strandweiss62 RHD Amphicar sold at Mecum General Amphicar Discussion 2
C Amphicar with Buick V6! General Amphicar Discussion 4
DavidC Amphicar club gift. General Amphicar Discussion 3
Andreas Gomoll „The Uganda-Amphicar“ - Brakeparts needed... General Amphicar Discussion 0
Andreas Gomoll ... my Amphicar has some specials.... Restorations in progress 2
B Amphicar Tow Bar General Amphicar Discussion 0
B Celina Amphicar Record General Amphicar Discussion 3
T Amphicar Furniture General Amphicar Discussion 6
mike_israel Amphicar Hawaiian Shirts - Order Deadline Approaching General Amphicar Discussion 0
Jon March the 3 different Amphicar factory driveshafts General Amphicar Discussion 2
sdreich Amphicar Transmissions General Amphicar Discussion 12
L long distance moves for Amphicar General Amphicar Discussion 6
sdreich Amphicar Hubcaps on eBay and More General Amphicar Discussion 4
LSolheim 2018 Clearlake Seaplane - Amphicar: Fly & Swim-in General Amphicar Discussion 0
Jon March Amphicar chase-scenes General Amphicar Discussion 0
Midwest Amphicar Central Florida Amphicar Swim In General Amphicar Discussion 4
Jon March GREAT Amphicar footage from the hot new Northeast "Naples Swim" General Amphicar Discussion 0
scottamphi What Pertronix Fit My Amphicar General Amphicar Discussion 6
mike_israel Merry Christmas & Joy to the Amphicar World General Amphicar Discussion 1
BlueFin Scam Amphicar Ad General Amphicar Discussion 11
mike_israel New Amphicar Children's Book General Amphicar Discussion 4
mike_israel Amphicar on Jay Leno's Garage General Amphicar Discussion 9
B Amphicar Fuses?? General Amphicar Discussion 2
Jon March Sun June 7 - "worlds fair edition" Amphicar?! General Amphicar Discussion 2
mike_israel New Walt Disney World Restaurant Offers Amphicar Rides General Amphicar Discussion 42
mike_israel Do you think this part will fit an Amphicar General Amphicar Discussion 2
dutchamphi Inspector Clouseau-Amphicar episode 1968 General Amphicar Discussion 6
auburnamphi Amphicar Owners In Georgia General Amphicar Discussion 2
C Amphicar article in Maine Magazine General Amphicar Discussion 1
