Craig
I just got some pictures from my body shop on the progress with the
sods blasting. The car is completely striped to bear metal now.
Looking at the photos it is clear that I have some trapped moisture
inside the frame rails that is weeping out on the bear metal. I have
read the posts and seen the photos regarding inspection ports and
drain holes but I'm wondering what I can do to protest the area once
the moisture is out. I have access to ultrasonic inspection equipment
at work and plan to do some scans to see if I have any corrosion
evident. If any of you experts would like to see the photos I have
them in a PDF format.
Craig in Alaska...
Craig in Alaska...
