Amphicar Battery
A Group 22NF is what fits the original metal box. Watch the terminal placement since that series has some variation of the terminals.
Tedredamphi
I ended up buying an I-45 battery from Interstate Batteries. The case dimensions are identical to the 22NF. 22NF has 390 cold cranking amps while the I-45 has 480 cold cranking amps. Terminals are reversed on the I-45, which will look correct if you have converted to negative ground.
Ted
Canadian four amphs
I use the AC DELCO battery.. series 55 aval with posts for pos. or neg ground, will be putting one in Tommys car and will post the exact # for pos ground then.
Its always good to buy one from a company that is continet wide incase of war. problems down the road.
GORD.
Amphicar Forum Admin
Staff member
I am a HUGE fan of Optima spiral cell batteries for the Amphicar, they do come in various group sizes.
Optima will NEVER leak acid so will not be the cause of rust. This is especially important if you still have a generator as boil-over is more likely. They can sit for extremely long periods without discharging, a big advantage in infrequently used cars. They will continue to work even fully submerged (don't ask me how I know).
My Optima battery is now going on 10 years old which I think is amazing. It has almost become a science experiment to see when it will finally die.
You can buy the Optima batteries on Amazon with free shipping! There was recently a $25 dollar rebate running on them as well but it may have run out this month.
webtoes64
I agree w/Mike's comments on Optima batteries.
I have had an Optima battery in my amphi for the last 18+ years...
I left the first one in for 10+ years and then swaped it out to a land yacht that needed a new battery and purchased a new Optima for Amphi... the replacement is now going on over 8 years and still working like a charm.
If you replace the battery cables w/new ones at the time of Optima install you will never see a hint of battery acid corrosion.
As Mike said... there is almost zero discharge from sitting idle.
Also the cold cranking amps are not affected by extreme cold temps like a conventional lead acid battery.
They are available at part stores and batteries plus etc... but check around because you can find quite a bit of price difference between sellers.
Steve B
Canadian four amphs
Ok Im back on line at Rehab center,
Comp. in next room..
I did go out and get the # off battery but Ar plane crash,, and here I am
Cant remember all the # but was Delco with 51 in the formula
GORD SOUTER
Canadian four amphs
GORD.
plane crash has put me in hospital;:012: I do remember #51 in the delco part
chasgould
Hey Gord,
Great to hear your "voice". We are all happy that you are okay, and that you are on the mend. That must have been a really scary episode. I hope that you will continue to heal quickly, and it is great to have you back.
Charles
C AMPHICAR BATTERY General Amphicar Discussion 2
J 1967 Amphicar Tub Toy Restorations in progress 3
mike_israel The only car I consider to be way cooler than the Amphicar General Amphicar Discussion 2
T Parting ways with my 64 Amphicar General Amphicar Discussion 0
AmazingOne Restored 1964 Amphicar for sale General Amphicar Discussion 0
chapron67 Wanted to buy: Nice, useable Amphicar. General Amphicar Discussion 3
mike_israel Annual costs of maintaining an Amphicar (Forum) ... General Amphicar Discussion 10
Jon March lot #012 - The next big Amphicar auction: end of This week! - lot #012 General Amphicar Discussion 4
strandweiss62 RHD Amphicar sold at Mecum General Amphicar Discussion 2
C Amphicar with Buick V6! General Amphicar Discussion 4
DavidC Amphicar club gift. General Amphicar Discussion 3
Andreas Gomoll „The Uganda-Amphicar“ - Brakeparts needed... General Amphicar Discussion 0
Andreas Gomoll ... my Amphicar has some specials.... Restorations in progress 2
B Amphicar Tow Bar General Amphicar Discussion 0
B Celina Amphicar Record General Amphicar Discussion 3
T Amphicar Furniture General Amphicar Discussion 6
mike_israel Amphicar Hawaiian Shirts - Order Deadline Approaching General Amphicar Discussion 0
Jon March the 3 different Amphicar factory driveshafts General Amphicar Discussion 2
sdreich Amphicar Transmissions General Amphicar Discussion 12
L long distance moves for Amphicar General Amphicar Discussion 6
sdreich Amphicar Hubcaps on eBay and More General Amphicar Discussion 4
LSolheim 2018 Clearlake Seaplane - Amphicar: Fly & Swim-in General Amphicar Discussion 0
Jon March Amphicar chase-scenes General Amphicar Discussion 0
Midwest Amphicar Central Florida Amphicar Swim In General Amphicar Discussion 4
Jon March GREAT Amphicar footage from the hot new Northeast "Naples Swim" General Amphicar Discussion 0
scottamphi What Pertronix Fit My Amphicar General Amphicar Discussion 6
mike_israel Merry Christmas & Joy to the Amphicar World General Amphicar Discussion 1
BlueFin Scam Amphicar Ad General Amphicar Discussion 11
mike_israel New Amphicar Children's Book General Amphicar Discussion 4
mike_israel Amphicar on Jay Leno's Garage General Amphicar Discussion 9
B Amphicar Fuses?? General Amphicar Discussion 2
Jon March Sun June 7 - "worlds fair edition" Amphicar?! General Amphicar Discussion 2
mike_israel New Walt Disney World Restaurant Offers Amphicar Rides General Amphicar Discussion 42
mike_israel Do you think this part will fit an Amphicar General Amphicar Discussion 2
dutchamphi Inspector Clouseau-Amphicar episode 1968 General Amphicar Discussion 6
auburnamphi Amphicar Owners In Georgia General Amphicar Discussion 2
C Amphicar article in Maine Magazine General Amphicar Discussion 1
