Amphicar 1147 engine ready to bolt in and use
This is a 1147 Triumph Herald engine out if a late model Amphicar. I was told it was rebuilt by a relative of the previous owner of the car. It definitely looks like it since it is so clean. It has a new clutch and fuel pump on it. I removed the valve cover and it’s spotless inside! Also if looks like the intake manifold gasket was recently replaced and the manifold has new studs with stainless nuts. It also has an extended oil dipstick that you can actually reach without burning your arms! I drove it around last summer and it ran great in the water and on land! It might need a carburetor rebuild, I removed the carb from my other Amphi to drive it and that doesn’t come with it. No shipping. Pick up in NH until October. Can bring to central Fla. After that. $2500.
