I had read some comments about using the original Amphi wheel rims with radial,
tubeless tires. There was one comment that the original Amphi rim was intended
for use with an inner tube, and didn't have a "safety bead" on the rim like rims
intended for tubeless tires.
Is anyone using radial, tubeless tires with the original rims? Assuming the
"safety bead" comment is right, is it safe to use a radial tire only if you also
use an inner tube? Or is the "safety bead" for the retention of the tire on the
rim, and, if you want to go to radials, should you replace the rims?
