Amphi Wheel Rims
OK, so here's my last word on wheel rims. This is based on actual measurements
of my four rims.
Bolt circle pattern is 5 x 112 mm.
The spindle stud holes are sized to fit a 14x1.5 millimeter stud.
The outboard side of each spindle stud hole is faced to accept Ball style lug
nuts.
The center hole in the wheel is 2.5" diameter.
The Rim Width (where the tire bead rests against the rim) is 4.5".
The Amphi wheel is a Positive Offset design, where the plane of the wheel/hub
surface is outboard of the center of the Rim Width.
The amount of Offset is 1.125" positive.
The Back Space (the distance from the plane of the wheel/hub surface to the
plane of the inner rim inside edge) is 3.875".
The Inner Diameter of the wheel, at the plane of the wheel/hub surface, is
10.75".
The Inner Diameter of the wheel, at the inside rim flange, is 12.5".
(For anyone who would like a dimensioned drawing of an Amphi wheel rim, I just
uploaded my Wheel Rim Drawing to the Yahoo Files site.)
