Amphi Shiocks
K
Ken ''KD'' Roy
Has anyone taken a spring of the shock & tested it?"
I was curious was the sping load was.
Till later.....
Ken Roy
L
Larry & Nancy Solheim
<font face="arial black">Ed Price, I believe, did some testing a ways back in relation to the Surplus Center snowmobile shocks.. Here's a clip of the results, Ken:</font> <div class="MsoNormal" style="MARGIN: 0in 0in 0pt"><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">I finally got around to measuring the spring rate for my Amphi front coil springs. I also measured the rate for a new Maeco PK22K1 coil-over shock (available from Surplus Center at $20 each). Here's the results:</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">For 1 inch of compression:</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">Original Amphi Front Spring #1: 172 pounds</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">Original Amphi Front Spring #2: 145 pounds</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">Maeco PK22K1 Shock & Spring: 180 pounds</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">For 2 inches of compression:</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">Original Amphi Front Spring #1: 350 pounds</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
Amphi Front Spring #2: 304 pounds</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">Maeco PK22K1 Shock & Spring: 310 pounds</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">Averaged out, the spring rates for each are:</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">Original Amphi Front Spring #1: 175 pounds per inch</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">Original Amphi Front Spring #2: 152 pounds per inch</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier
New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">Maeco PK22K1 Shock & Spring: 155 pounds per inch</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">I conclude that one of my front springs is a bit weaker than the other. I also see that the Maeco is very similar to the original Amphi springs. So, I'm going to follow Ken Chambers advice and use the pair of new Maecos on the front of my Amphi.</font></span></tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">
</span><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="courier">BTW, the Amphi shocks have an extended length of 13" and a stroke of 3.5". The Maeco shock has an extended length of 13.25", and a stroke of 3.5". This is so close as to be identical.</font></span></tt> <div class="MsoNormal" style="MARGIN:
0in 0in 0pt"><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="Courier"></font></span></tt> <div class="MsoNormal" style="MARGIN: 0in 0in 0pt"><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="arial black">No one responded to my request for the actal weight of the front end of an Amphicar, but based upon a 38/62%weight distribution I figure the front end load at about 880#.</font></span></tt> <div class="MsoNormal" style="MARGIN: 0in 0in 0pt"><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="arial black"></font></span></tt> <div class="MsoNormal" style="MARGIN: 0in 0in 0pt"><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="arial black">I've sentmy ALDAN shocks back for rebuild (again) under the lifetime warranty. I'm going to five them one more try, w/ the springs adjusted a long as possible.</font></span></tt> <div class="MsoNormal" style="MARGIN: 0in 0in 0pt"><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="Arial Black"></font></span></tt> <div class="MsoNormal" style="MARGIN: 0in 0in 0pt"><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="Arial Black">Something I didn't mention during my recent alignment episode, the technician (owner) of the shop noted that I w/ the Maeco shocks I had virtually NO front end suspension. All of the movement was coming from the tires. Even w/ two of us pulling on the bumper we couldn't get spring flex. With the "topping" I has w/ the ALDAN shocks and original springs, it makes me wonder if the original Amphicar springs are a bit too strong for the vehicle weight.</font></span></tt> <div class="MsoNormal" style="MARGIN: 0in 0in 0pt"><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="arial black"></font></span></tt> <div class="MsoNormal" style="MARGIN: 0in 0in 0pt"><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"><font face="Arial Black">--Larry</font></span></tt> <div class="MsoNormal" style="MARGIN: 0in 0in 0pt"><tt><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'"></span></tt>
Ken 'KD' Roy <kdroy@hotmail.com> wrote: <blockquote class="replbq" style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid">
Till later.....
Ken Roy
</blockquote>
<hr size="1">Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2?/min or less.
RalphF Georgia Amphi Restoration Restorations in progress 6
RalphF Amphi Shirt General Amphicar Discussion 4
mike_israel Amphi article in Classic Motorsports Magazine General Amphicar Discussion 0
mike_israel The Time Has Come ... Selling the Amphi General Amphicar Discussion 7
SNOWBIRD 1965 Amphi project General Amphicar Discussion 1
Jon March Insurance when towing Amphi vs when on road? General Amphicar Discussion 5
Jon March Suddenly "revving up" when in water -Does your Amphi do this? General Amphicar Discussion 13
Jon March Anyone know who ended up buying this Amphi? General Amphicar Discussion 1
SNOWBIRD 64 Amphi??? General Amphicar Discussion 0
mike_israel OT: Something like this could be useful for Amphi and parts purchases General Amphicar Discussion 0
SNOWBIRD Amphi bottoms General Amphicar Discussion 1
Jon March we could all use help with this Amphi issue: General Amphicar Discussion 0
mike_israel Amphi on Bring a Trailer General Amphicar Discussion 2
mike_israel What did you do to your Amphi today? General Amphicar Discussion 16
Bilgemaster Original Amphi Key No. 5415? General Amphicar Discussion 13
Mark Richardson RHD Museum Amphi sells at BJ auction this weekend..... General Amphicar Discussion 2
Mark Richardson 2017 Barrett-Jackson auction includes single Amphi General Amphicar Discussion 7
Cameron in UK Anyone know the source of this New York Amphi photo ? General Amphicar Discussion 6
dutchamphi Amphi-scooter General Amphicar Discussion 1
SNOWBIRD A blip on Fred's Amphi. General Amphicar Discussion 0
mike_israel Future Amphi Owner Earns Eagle Scout General Amphicar Discussion 3
mike_israel Toolbox Deal at Home Depot (No Amphi Content) General Amphicar Discussion 0
Mark Richardson Amphi sold at Barrett Jackson tonight General Amphicar Discussion 0
mike_israel Securing Amphi and Trailer General Amphicar Discussion 7
mike_israel Non-Amphi garage project - shelves General Amphicar Discussion 4
amphi-Ben Amphi Swim In the Netherlands General Amphicar Discussion 3
mike_israel It's the Amphi-Jeep for Less than $2k General Amphicar Discussion 1
azpaul50 Amphi with Spare Harley behind! General Amphicar Discussion 0
SNOWBIRD Another Amphi swims General Amphicar Discussion 0
A Barn Find 1965 Amphi Restorations in progress 3
Midwest Amphicar Why you should visit Florida with your Amphi General Amphicar Discussion 1
Midwest Amphicar Amphi fins and snow drifts General Amphicar Discussion 4
Mark Richardson Barrett-Jackson Auction Amphi General Amphicar Discussion 2
Midwest Amphicar Another sweet Ebay Amphi General Amphicar Discussion 0
Midwest Amphicar Sweet Ebay Amphi General Amphicar Discussion 2
azpaul50 Amphi at Auction General Amphicar Discussion 0
azpaul50 Home-made Amphi in Calexico, CA General Amphicar Discussion 2
Midwest Amphicar Did you put a gift under the tree for your Amphi? General Amphicar Discussion 4
Midwest Amphicar warm weather memory or how to dry amphi General Amphicar Discussion 3
Midwest Amphicar Driving Amphi to Florida from Illinois ?! General Amphicar Discussion 0
F amphi in a video General Amphicar Discussion 6
Midwest Amphicar Christmas Present,Green Amphi for sale General Amphicar Discussion 3
laserfixr Amphi on HDTheater General Amphicar Discussion 2
T Amphi in Restaurant Ad General Amphicar Discussion 3
Ed Price FW: Amphi Model on YouTube General Amphicar Discussion 0
cigarman Amphi model that swims General Amphicar Discussion 0
Midwest Amphicar G PA Wave visits Mikes Amphi General Amphicar Discussion 4
