amp gauge wiring
Tom Maruska
I'm about to install an amp gauge in my amphicar and I still have the
generator and a positive ground system.
Can someone please tell me where to connect the two wires from the gauge?
Thanks!
WB6WSN
Sent: Wednesday, September 22, 2004 10:10 AM
Subject: [amphicar-lovers] amp gauge wiring
Thanks!
With the caution that my Amphi has no wiring in it right now, and that I'm
looking at the big, laminated Amphi schematic, here goes.
You want to install an ammeter between the battery an all electrical loads
(except the starter and starter relay, which draw a huge amount of current, for
only a very short time).
I would lift the Red wire off of Terminal 51 of the Starter Solenoid Switch
(Item #44). Connect the positive terminal of the ammeter to the lug on the red
wire and connect the negative terminal of the ammeter to the newly vacated
Terminal 51.
You could also do this at the Regulator (Item #43). Here, connect the ammeter
positive to the Red wire, and connect the ammeter negative to Terminal 51 on the
Regulator.
This arrangement puts the generator and regulator on the load side of the
ammeter. After all, you don't want to measure how much current the generator is
supplying to the car, you just want the net flow in/out of the battery. This
arrangement also protects the ammeter from damage caused by the several hundred
Amps that the starter motor tries to draw when you turn the key. Remember, you
should have no connections to the battery negative terminal other than the
single heavy battery cable that runs to the Starter Solenoid Switch.
I think the Switch is easier to get at than the Regulator. I am assuming that
you are using a simple ammeter, not a shunt ammeter. Also, use fairly heavy wire
to run between the ammeter and the point of insertion; I suggest #10 stranded.
Also, use proper crimped and soldered wire lugs, or a proper wire-nut. I suggest
a 30/0/30 Amp ammeter; I think it would be rare to ever draw more than 30 Amps
to the car's load, and the stock generator can't charge more than about 15 Amps
anyway.
If you want to use a shunted ammeter, this is technically nicer, but has a
slightly more complicated wiring requirement. I'll get into that only if you
need me to.
El Cajon, CA USA
Tom Maruska
Thanks a lot Ed!
Yes it is a simple amp meter and I'll let you know later today how it went.
I'm also installing an hour meter which I'm connecting into the prop
light circuit to keep track or water time, and a new fangled Faria Pilot
I combination depth sounder, water temp, water speed and water distance
traveled. Should have it all done today and then I'll put a couple
picts on my amphi website.
> From: Tom Maruska
> gauge?
> Thanks!
> I'm looking at the big, laminated Amphi schematic, here goes.
> loads (except the starter and starter relay, which draw a huge amount
> of current, for only a very short time).
> Switch (Item #44). Connect the positive terminal of the ammeter to the
> lug on the red wire and connect the negative terminal of the ammeter
> to the newly vacated Terminal 51.
> ammeter positive to the Red wire, and connect the ammeter negative to
> Terminal 51 on the Regulator.
> the ammeter. After all, you don't want to measure how much current the
> generator is supplying to the car, you just want the net flow in/out
> of the battery. This arrangement also protects the ammeter from damage
> caused by the several hundred Amps that the starter motor tries to
> draw when you turn the key. Remember, you should have no connections
> to the battery negative terminal other than the single heavy battery
> assuming that you are using a simple ammeter, not a shunt ammeter.
> Also, use fairly heavy wire to run between the ammeter and the point
> of insertion; I suggest #10 stranded. Also, use proper crimped and
> soldered wire lugs, or a proper wire-nut. I suggest a 30/0/30 Amp
> ammeter; I think it would be rare to ever draw more than 30 Amps to
> 15 Amps anyway.
> has a slightly more complicated wiring requirement. I'll get into that
> only if you need me to.
> Ed
> El Cajon, CA USA
> 67 Rust Guppy
> THE AMPHICAR-LOVERS LIST
> Archives:
> visit:
> amphicar770@yahoo.com
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> click here
<<a href="http://us.ard.yahoo.com/SIG=1290r97pp/M=295196.4901138.6071305.3001176/D=groups/S=1705064625:HM/EXP=1096022872/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com">http://us.ard.yahoo.com/SIG=1290r97pp/M=295196.4901138.6071305.3001176/D=groups\
/S=1705064625:HM/EXP=1096022872/A=2128215/R=0/SIG=10se96mf6/*http://companion.ya\
hoo.com</a>>
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> <mailto:amphicar-lovers-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
Tom Maruska
All dond and working. Only difference was I had to connect the wires
reverse of how you described to get the needle on the right side of center.
" > I would lift the Red wire off of Terminal 51 of the Starter Solenoid
> to the newly vacated Terminal 51."
This is how it works: Connect the positive terminal of the ammeter to
the newly vacated Terminal 51 and connect the negative terminal of the
ammeter to the
lug on the red wire.
I took it ou and water tested the depth/speed gauge today too, works
great, here's some pictures:
http://www.cpinternet.com/~tpls63/amphi/amphi17.html
Tom Maruska wrote:
> Thanks a lot Ed!
> went.
> > From: Tom Maruska
> > gauge?
> > Thanks!
> > 15 Amps anyway.
> > Ed
> > El Cajon, CA USA
> > 67 Rust Guppy
> > Archives:
> > visit:
> sponsors at:
> > ADVERTISEMENT
> > click here
hoo.com</a>>
> > Yahoo! Groups Links
> Archives:
> visit:
> ADVERTISEMENT
> click here
<<a href="http://us.ard.yahoo.com/SIG=1298jqqef/M=295196.4901138.6071305.3001176/D=groups/S=1705064625:HM/EXP=1096025765/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com">http://us.ard.yahoo.com/SIG=1298jqqef/M=295196.4901138.6071305.3001176/D=groups\
/S=1705064625:HM/EXP=1096025765/A=2128215/R=0/SIG=10se96mf6/*http://companion.ya\
hoo.com</a>>
> Yahoo! Groups Links
Michael Echemann
Tom:
Your gauges look great. For that matter so does the entire car. I bet the
guy in Moose Jaw Canada would be shocked to see it now even though it was a
good solid car originally. A beautiful job!
Sent: Thursday, September 23, 2004 8:09 PM
Subject: Re: [amphicar-lovers] amp gauge wiring
ammeter to the
Tom Maruska wrote:
> Thanks a lot Ed!
> went.
> > From: Tom Maruska
> > gauge?
> > Thanks!
> > 15 Amps anyway.
> > Ed
> > El Cajon, CA USA
> > 67 Rust Guppy
> > Archives:
> > visit:
> sponsors at:
> > ADVERTISEMENT
> > click here
<http://us.ard.yahoo.com/SIG=1290r97pp/M=295196.4901138.6071305.3001176/D=gr
anion.yahoo.com>
> > Yahoo! Groups Links
> Archives:
> visit:
> ADVERTISEMENT
> click here
<http://us.ard.yahoo.com/SIG=1298jqqef/M=295196.4901138.6071305.3001176/D=gr
anion.yahoo.com>
> Yahoo! Groups Links
Yahoo! Groups Links
Tom Maruska
Thanks Mike!
Find any more for me?
Michael Echemann wrote:
> Tom:
> bet the
> was a
> Mike
> From: "Tom Maruska" <tpls63@cpinternet.com>
> center.
> ammeter to the
> <http://www.cpinternet.com/%7Etpls63/amphi/amphi17.html>
> Tom Maruska wrote:
> > Thanks a lot Ed!
> > went.
> > > From: Tom Maruska
> have the
> > > gauge?
> > > Thanks!
> > > 15 Amps anyway.
> > > Ed
> > > El Cajon, CA USA
> > > 67 Rust Guppy
> > > Archives:
> > > visit:
> > sponsors at:
> > > ADVERTISEMENT
> > > click here
> anion.yahoo.com>
> > > Yahoo! Groups Links
> > Archives:
> > visit:
> sponsors at:
> > ADVERTISEMENT
> > click here
> anion.yahoo.com>
> > Yahoo! Groups Links
> Archives:
> visit:
> Yahoo! Groups Links
> Archives:
> visit:
> ADVERTISEMENT
> click here
<<a href="http://us.ard.yahoo.com/SIG=129h77p5b/M=295196.4901138.6071305.3001176/D=groups/S=1705064625:HM/EXP=1096078640/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com">http://us.ard.yahoo.com/SIG=129h77p5b/M=295196.4901138.6071305.3001176/D=groups\
/S=1705064625:HM/EXP=1096078640/A=2128215/R=0/SIG=10se96mf6/*http://companion.ya\
hoo.com</a>>
> Yahoo! Groups Links
