alternators
  • Thread starter Thread starter robert millman
robert millman
What is the best alternator to use? My car was converted previously and my alternator has recently failed. My mechanic says it is really too big (70amps) for my needs and it was likely the cause of my once a year battery replacement. Robert '66 White in Boston
<hr size="1">Sneak preview the all-new Yahoo.com. It's not radically different. Just radically better.
<font face="Arial" size="2">Triumph fitted alternators to theengine from about 1967 to end of production around 1980. You just need to find a Spitfire from that era. As well as the alternator there is a small mounting block and then it just bolts straight on. Looks factory original.. because it is ! Works great on Amphicar and should be easy to find even over there. Google for articles with detail, as well as Amphicar search for Triumph Herald and Spitfire alternator. Remember the UK word for a generator is a dynamo.</font>
<div style="BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: black">From: robert millman
<div style="FONT: 10pt arial">Sent: Wednesday, June 28, 2006 2:10 PM
<div style="FONT: 10pt arial">Subject: [amphicar-lovers] alternators
<div id="ygrp-text">
Robert
'66 White in Boston
<hr SIZE="1">
</blockquote>
--- In amphicar-lovers@yahoogroups.com, robert millman
Robert -
Use any single wire GM alternator. The 70A rating has nothing to do
with your battery replacements. The internal regulator that eventually
failed is your culpret. The regulator does just that, it regulates the
power depending on the needs of the system. When they quit working, it
will over produce and cook your battery or under-produce and discharge
the battery.
John Bevins
Robert,
I agree with Dave Chapman about the Triumph (Lucas)alternator. It has
proper mounts for the engine and even has the same terminals that the
Amphicar uses so you can simply plug it in place. You can see such an
alternator in my "1296 engine" photos in the "photo" section of this
website. I bought mine at Kragen auto parts. It's a rebuild done by
Autolite and their part number is 14029. I believe it is a 35 amp.
alternator but your old alternator didn't kill the battery by being
too large. It just went bad. Like Dave Chapman said, they were used
for many years on Triumphs and the mounting parts, fan and pulley will
probably be found at a local junk yard or you can buy these parts new
from the "Victoria British" parts catalog.
This alternator is a 2 wire installation. With this installation your
"idiot light" on the dash works correctly and I don't think that's
true with a Delco, one wire installation. It also looks "correct"
because it is correct for this engine.
Note to others in this group: Installing an alternator in an Amphicar
normlly requires that the car has been converted to negative ground
operation. It's not a hard job to do and I've done it to both my
cars. Just a note so that you don't try to install such an alternator
without doing the conversion. That would be a bad thing.
> Robert
> '66 White in Boston
Re: Re: alternators
John Friese wrote:
> Robert,
> John Friese
I understand the desire to tinker, but I have had no issues with the
factory generator setup. Why go through all this trouble?
Dan
Re: Re: alternators
<font FACE="arial,helvetica"><font SIZE="2" PTSIZE="10" FAMILY="SANSSERIF" FACE="Arial" LANG="0">In a message dated 6/28/2006 5:57:55 PM Central Daylight Time, dkgibson3@comcast.net writes:
<blockquote TYPE="CITE" style="BORDER-LEFT: #0000ff 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px">
Dan
</blockquote>
Just because---
Because, alternator's are more reliable, they put out more voltage at lower rpms, they eliminate the normal voltage regulator which is another source of trouble, ect ect
also you can put in a modern radio with a CD.
But its not original, so a car with one will NEVER bring $115K at auction, but then I doubt that one with a generator will ever again, at least not anytime soon.
Just my too cents--been kinda slow lately.</font>
Mainly because it allows you to use nice radios in the car and to plug
in things like GPS units to the cigarette lighter without fooling
around with adapters. I have two 5x7 speakers mounted under the dash
where the 4" hole used to be and on the other side, a nice AM/FM
stereo radio that fits the original holes in the dash and an older
Alpine booster to power the speakers with more than the couple of
watts that regular radios would provide. I also use a moderm,
miniature tachometer mounted along side of the steering column.
None of this is easy to do with a positive ground system.
--- In amphicar-lovers@yahoogroups.com, Daniel & Kathy Gibson
<dkgibson3@...> wrote:
> John Friese wrote:
> > Robert,
> > John Friese
> Dan
Re: Re: alternators
>> Dan
> Just because---
I have put several thousand miles on land, and countless hours on the
water so far with no issues...but I do not have a fancy radio, so maybe
that is why. As far as the auctions are concerned...I wonder if the
people bidding would have a clue if an Amphicar was original or not!
Dan
In five years of owning my Amphicars and talks with hundreds of people
about them, I've never talked to anyone, except Mike Echemann, who
cared a bit about it being all original. They only care about how
well it works and how good it looks. The changes I make with my car
have to do with performance and reliability, since I drive my cars
everywhere and don't trailer them, and I always try to do things that
can be reversed if someone should ever want to do that.
> dkgibson3@... writes:
> > Dan
> Just because---
at lower
source of
> trouble, ect ect
auction,
not anytime
> soon.
Re: Re: alternators
<font face="Arial" size="2">John,</font>
<font face="Arial" size="2">Thanks for the compliment!!! I think? :-)</font>
<font face="Arial" size="2">I see your point about wanting to improve performance and add accessories. I often consider that as well. All my cars are untouched so I hesitate to change stuff. My 64 green caris the only one that gets used andunfortunatelythese dayonly once a year at Celina. I'm mellowingsome.Idid install a radio with power inverter!!!!</font>
<font face="Arial" size="2">My thoughts on originality are that most buyers have no idea what is correct when buying.I often wonder ifhigh dollar buyers are disappointed when they find out how incorrect their cars are. Right now everything seems to be selling so it doesn't matter. Collectors will eventually want to know what is original. As a group/club we don't have any interest in judging orcertifying certain cars as "correct". If we did amphi prices would still be high across the board but the certified correct examples would be getting very huge premium pricesright now.The long term benefit to the brand would be that cars would be more originality restored. </font>
<font face="Arial" size="2">Amphi's are for having fun anyway so as long as we leave a few for the future that's what's important. Your cars are as nice as I've seen and you can return it to original without any problems so why not make them easier to drive and enjoy. I understand there are a few Cool Looking customs amphi's being built and I can't wait to see them too. </font>
<font face="Arial" size="2">Mike</font>
<div style="BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: black">From: John Friese
<div style="FONT: 10pt arial">Sent: Thursday, June 29, 2006 12:58 AM
<div style="FONT: 10pt arial">Subject: [amphicar-lovers] Re: alternators
> dkgibson3@..<wbr>. writes:
> > Dan
> Just because---
at lower
source of
> trouble, ect ect
auction,
not anytime
> soon.
</blockquote>
Hi Mike,
Not really a compliment or a complaint. Just an observation.
Some time ago there was a car show on TV where some "famous" hot rod
guy (Boyd Coddington) was chopping up a perfectly maintined, not
restored, 20's or 30's car. This car was in such perfect shape that
his employees at his custom shop were upset that he was trashing a
rare survivor to make a hot rod. It pissed me off so much I've never
watched the show again. I hate that stuff.
Amphicars are a slightly different kind of car though because, thanks
to the support network in place, you can actually use these cars and
still keep them in top shape. They are also so unusual that people
get a lot of joy just watching them go. You can't say that about a
lot of old cars. I often feel a bit sad seeing those "museum" cars
that never get driven. I've often thought about some of those super
low mileage, original cars you've found and I really don't know what
I'd do with them. I wouldn't want to spoil the "cherry" of those cars
and would be bothered by using them. But then I haven't placed high
value on virgins for many years now either. Some things are just
meant to be used.
Enjoy,
--- In amphicar-lovers@yahoogroups.com, "Michael Echemann"
<echemike@...> wrote:
> John,
untouched so I hesitate to change stuff. My 64 green car is the only
one that gets used and unfortunately these day only once a year at
Celina. I'm mellowing some. I did install a radio with power
inverter!!!!
correct when buying. I often wonder if high dollar buyers are
don't have any interest in judging or certifying certain cars as
premium prices right now. The long term benefit to the brand would be
too.
> Mike
> From: John Friese
> John Friese
> 67 White
> 67 Red
> > dkgibson3@ writes:
with the
> > > Dan
> > Just because---
> at lower
> source of
> > trouble, ect ect
> auction,
> not anytime
> > soon.
RE: Re: alternators
<table style="BACKGROUND-COLOR: #ffffff">
<div class="OutlookMessageHeader" lang="en-us" dir="ltr" align="left"><font face="Tahoma" size="2">From: amphicar-lovers@yahoogroups.com [mailto:amphicar-lovers@yahoogroups.com] On Behalf Of John Friese
Sent: Wednesday, June 28, 2006 7:33 PM
</font><span class="537311709-30062006"><font face="Century Schoolbook" color="#ff0000" size="4"></font></span>
<div class="OutlookMessageHeader" lang="en-us" dir="ltr" align="left"><span class="537311709-30062006">Mainly because it allows you to use nice radios in the car and to plug
</span>
<div class="OutlookMessageHeader" lang="en-us" dir="ltr" align="left"><span class="537311709-30062006"></span>
<div class="OutlookMessageHeader" lang="en-us" dir="ltr" align="left"><span class="537311709-30062006"><font face="Century Schoolbook" color="#0000ff" size="4">Another point is that alternators are inherently less electrically noisy than generators. As the multiple bars of the brass commutator slip past the carbon brushes, each bar makes a mini-lightning discharge. You hear this as a staccato "whine" in your radio. Also, alternators use an electronic regulator, while generators use an external voltage regulator. Inside the voltage regulator, there's a relay that's continuously "chattering", matching field current to generator load. That's another source of RF noise, and another mechanical part to wear out.</font></span>
<div class="OutlookMessageHeader" lang="en-us" dir="ltr" align="left"><span class="537311709-30062006"><font face="Century Schoolbook" color="#0000ff" size="4">All this RF noise wasn't too bad back in the 50's, when auto radios had a "vibrator" power supply that caused plenty of hum that helped to mask the whine. Modern auto electronics almost universally expects to see an alternator system, and you might get some noisy performance using them with a generator system.</font></span><span class="537311709-30062006"><font face="Century Schoolbook" color="#0000ff" size="4"></font></span></blockquote>
<span class="537311709-30062006"><font face="Century Schoolbook" color="#0000ff" size="4">You can keep your Amphi original with a generator, but generators are not coming back for automotive systems.</font></span>
<div align="left"><font color="#0000ff" size="4"></font><font face="Century Schoolbook" color="#0000ff" size="4"></font></span>
</blockquote>
> John Friese wrote:
> > Robert,
> > John Friese
> Dan
My reasoning has always been that anything that I can do that loosens
The Dark Lord Lucas's grip on my cars electrical system can only be a
good thing. :)
Peter
Robert,
Check back on the 28th. We did several postings regarding alternator
installation.
> Robert
> '66 White in Boston
--- In amphicar-lovers@yahoogroups.com, "John Friese" <jfriese@...>
wrote:
> Robert,
alternator
> installation.
> John Friese
> > Robert
> > '66 White in Boston
different.
>Hi Robert my name is Bruce and I was wondering if you knew of any
ampbibicars for sale and what it is like to drive one on the road and
water.
Bruce01748com@yahoo.com
Replies
Views
682
alaskanamphi
