alls dwell that ends dwell
David Derer
Gap this.If you have a used engine use specs to get it started. Now that
it is running spend some quality time and adjust it to run in your neck
of the woods. Also I bet you have not taken apart your distributor and
cleaned those springs and checked your wieghts. What is the correct
timing for your stretched out timing chain, worn cam, tired lobe
distributor? So dwell on this. Later Dave the Wave
