DougFromBaltimore
Has anyone successfully fitted an aftermarket water temperature gauge to their +ground Amphicar? I purchased a nice VDO gauge, which I intend to tastefully install under the instrument panel to replace the function of the tiny original gauge in the instrument cluster.
I’ve been testing the new VDO gauge with a battery, placing the sensor in hot water. Set up as negative ground, it works properly. It has three terminals: +12V, -ground, and the sender, which goes to ground when the temperature rises (rising temp is less resistance at the sender).
The VDO tech told me to just reverse the +12 and – ground terminals. It appears that would work, but sweep of the needle must be polarity sensitive – the needle goes the wrong direction.
Any suggestions on how to wire this gauge?
How to rewire the gauge inside?
Another brand gauge you’d recommend?
Note: I don’t want to convert the car from positive to negative ground.
Thanks, Doug
Thanks, Doug
