Accelerator cable length
amphiguru
The cable length is controlled by the muffler bracket at the front
of the muffler. If the muffler bracket is positioned too close to
the convertible top area, the cable will not reach the stock
Amphicar carburetor linkage. Properly positioned, our cable (the
original Amphicar cable) will easily fit the linkage of the larger
side draft or down draft Weber carburetors; in spite of the fact
that the linkage attachment is about ? to ? of an inch further back
toward the radiator. Also, if you fabricate a replacement muffler
and exhaust pipe, be sure to keep the measurements in mind.
Here are another couple of tips for accelerator cables (or any other
cable):
1. Before installing cable, hang it from a garage ceiling beam
and feed oil into the black housing. Let drain down overnight, then
install.
2. If your cable "sticks" when you push on the gas pedal,
install a weaker (not stronger) return spring. Sometimes a stronger
spring will make the cable wire apply too much pressure to the
inside of the cable housing.
Best regards,
Hugh
Mark Richardson Accelerator cable installation question General Amphicar Discussion 17
D accelerator cable General Amphicar Discussion 1
D Accelerator pedal - one for Hugh General Amphicar Discussion 0
B Accelerator/Clutch Problem General Amphicar Discussion 1
Jon March Handbrake cable - where it enters from outside General Amphicar Discussion 1
S Speedometer Cable - Update General Amphicar Discussion 0
S Speedometer Cable Replacement General Amphicar Discussion 4
A NEW CHOKE CABLE General Amphicar Discussion 1
D fight ing the clutch cable General Amphicar Discussion 3
R choke cable General Amphicar Discussion 10
B SV: Re: clutch cable General Amphicar Discussion 0
T Brake Cable Routing ??? General Amphicar Discussion 4
S I need a choke cable General Amphicar Discussion 0
J Battery Cable Quick Connectors General Amphicar Discussion 0
R Stainless Throttle Cable General Amphicar Discussion 1
S clutch cable General Amphicar Discussion 13
R Cable cover and cheep tailpipe pipe seal General Amphicar Discussion 0
M How to install a new speedometer cable...... General Amphicar Discussion 0
T Brake and park cable question General Amphicar Discussion 2
A Speedometer Cable Lube General Amphicar Discussion 0
S shift linkage/clutch cable General Amphicar Discussion 1
E Steering Track Arm Length General Amphicar Discussion 1
A Seet belt length General Amphicar Discussion 6
M 64 Amphi Length General Amphicar Discussion 1
