a question about towing my Amphicar
Tommy in Tampa
Hi everyone, I have a question about towing my Amphicar.
OK we all know you can tow an Amphi on it wheels using a tow bar without damage.
Do you think you could use a car, a bigger car, like a Chrysler 300 as the tow vehicle? I want to tow the Amphi with a tow bar to Mt Dora using a car as the tow vehicle. What do you think, I think it will be fine. Let me know you opinion Please.
Tommy in Tampa waiten for Mt Dora GET YOUR ROOM NOW
Try this again, just made a fix to email update.
I know that Billy Syx uses a Lincoln Town car to tow his Amphi. However, that is a rear wheel drive, body on frame vehicle. The Chrysler 300C is rated to tow up to 3,800 pounds (Not too shabby) whereas the standard Chrysler 300 is rated at 2,000 lbs. For the former it should not be a problem. For the later you are pushing things a bit but FL is flat and if you are not going a greatr distance then should be OK.
BTW, I was testing out this "type between the lines format". While it would keep things looking neater (no AOL ads stuck at the bottom of messages) I am not sure if I like it so will switch back to not using it.
Cheers,
I tried typing between those lines as instructed, but nothing took.
Tommy, we have towed our Amphicar backwards on a tow dolly which is how we
always have towed it. Usually, we are towing with a Motor Home, but we also
have a Chrysler LHS which is basically the same in most respects as the 300
which I think is what replaced the LHS. We have towed it across the country
backwards on a tow dolly with the LHS with no problems - that is how I towed to
and from Lake Mirror. When we first bought it, we towed it back from
Pennsylvania that way with another LHS. I don't think it would make any difference
whether you were towing it on a tow dolly or 4 wheels on the ground - the
vehicles to which I refer are close to identical to your 300 - they just ceased
to produce the LHS when they brought out the 300 I believe.
Re the Lake Dora show - I concur - it would be prudent to make a room
reservation now rather than wait till they have been snatched up as there are
usually other events besides the Boat Show which occur that same weekend . For
anybody wanting to stay in an RV, there is a big RV Park just 3 miles SW of
Wooten Park which costs $35 a night for a full hook up. The Inn on the Green is
about 2 miles NE of the Park. If you call the Inn on the Green, be sure to
tell them you are part of the Amphicar Group in order to get the special
reduced rate which Dave Monier has arranged.
Vic Nelson with the 67 "Split Personality"
**************Biggest Grammy Award surprises of all time on AOL Music.
(http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025
48)
