28MM drive shafts
I am rebuilding a bunch of Drive shafts for stock. and have found I am short 1 piece.
I am looking for The 28 mm drive end that goes into the Transmission.
Boy I have seen some weird things done to these units threw the years,
people have machined out 24 mmm to fit a larger ??? u joint. Welded them in. You name it!
Hi Gord,
Is this the late production larger shaft?
I may have one, but will need to measure it to make sure. You want the whole shaft? (Both ends)
Here is a picture to ID it properly.
Mark
Hard to tell in pic/That unit looks like a 24mm Shaft but could be 28/ in poor shape.The splines on the long shaft look to come to a point instead of square.
Just looking for the pc. that goes in trany, with a useable seal surface /is that just surface rust?
Pic is of a 30 MM unit.
I would need to take it apart to measure, but think it is a 30mm.
Looking at the surface it does not look like it would seal, so not worth the effort. Sorry.IMG_20200401_224122461_HDR.jpg
