2005 Prices
amphiguru
Mike states he has heard our 2005 prices are much higher. Only some
parts are higher. In fact, many of the fastest selling parts are
much lower. (See partial list below.) All of us at Gordon Imports,
Inc. thank you very much for your support. We will confidently
introduce many new items in 2006.
Partial 2005 Price List
Part Number Description Old Price New Price Core
1-01-01bL Lower Gasket Set$62.02 $25.90
1-01-01bU Upper Gasket Set$71.70 $29.95
1-01-27 Carburetor Base Gasket $2.51 $0.99
1-02-17 Wooden Filler $3.91 $1.59
1-02-36 Oil Pan Gasket $9.77 $3.95
1-02-52 Valve Guide $5.66 $3.95
1-02-58 Cylinder Head Gasket $32.59 $19.95
1-02-59H Intake Valve $16.50 $8.95
1-02-60H Exhaust Valve $19.22 $9.50
1-02-62 Valve Spring $8.91 $6.75
1-02-64 Valve Tappet $35.85 $12.95
1-02-83 Valve Cover Gasket $4.69 $2.95
1-03-11a Starter Ring Gear $63.71 $39.95
1-03-23 Timing Chain $42.07 $19.95
1-03-26 Timing Cover Gasket $7.90 $5.95
1-03-37a.010 Rod Bearing, .010 $61.20 $29.95
1-03-37b.020 Rod Bearing, .020 $61.20 $29.95
1-03-37c.030 Rod Bearing, .030 $61.20 $29.95
1-03-37std. Rod Bearing, Std. $59.90 $25.95
1-03-48 Distributor Gasket $1.35 $0.90
1-03-48a Distributor Gasket $1.35 $0.90
1-04-02a/14 Water Pump $107.35 $99.95 $25.00
1-04-02a/14/21 Water Pump $107.35 $99.95 $25.00
1-04-14 Water Pump Gasket $6.15 $3.90
1-04-17 Water Pump Gasket $6.39 $3.25
1-04-29 Fan Belt $9.44 $7.95
1-04-32 Thermostat Gasket $2.31 $1.10
1-05-02/03 Oil Pump Assembly $129.02 $110.59
1-05-09 Manifold Gasket $11.97 $9.90
1-06-01R Fuel Pump with Primer $53.90 $29.90 $15.00
1-07-20 Acc. Pump Diaphragm $12.53 $7.95
1-07-43 Main Jet $12.79 $8.90
1-07-61 Carburetor Base Gasket $2.51 $0.99
1-11-05 Dist. Contact Points $5.05 $1.95
1-11-30/30a Spark Plug $2.37 $1.95
2-16-06 Seal $18.05 $12.95
2-16-37 Needle Bearing $34.07 $29.90
2-16-45 Needle Bearing Set $56.65 $39.10
2-16-50 Seal $16.35 $9.90
2-16-51 Ball Bearing $49.00 $29.95
2-17-11 Differential Bearing $53.71 $39.90
3-19-05 Propeller Bearing $41.79 $19.90
3-19-11 Propeller $290.00 $179.95
3-19-16 Oval Propeller Gasket $33.06 $19.20
3-19-21 Leg Gasket $3.48 $2.15
3-19-22 Kit Prop. U-Joint Kit $53.80 $29.95
4-20-11 Pinch Bolt $6.27 $3.95
4-20-17 Brass Bearing Bushing $121.95 $79.90
4-20-18 Brass Bearing Bushing $121.95 $79.90
4-20-27 Wheel Rim Studs $4.85 $2.95
5-21-09 Brass Bearing Bushing $121.95 $79.90
5-21-10 Brass Bearing Bushing $121.95 $79.90
5-21-23 Wheel Rim Studs $4.85 $2.95
6-22-07 Metal Brake Line $14.90 $9.50
6-22-08 Metal Brake Line $14.90 $9.50
10-33-09 Voltage Regulator $77.82 $59.95
11-34-33 Body/door Weatherstrip $25.79 $19.95
11-42-03 Pedal Pad $27.33 $19.95
Mike Israel
Hi Hugh,
Thanks for clearing things up. There was rumor going
round at Celina that an across the board price
increase of x% was coming along with the new catalogs.
Glad to hear this was just an urban legend. That is
also why I emphasized in my earlier message that this
rumor was unconfrimed.
Of course, at the rate fuel prices are rising, the
most valuable Amphicar's will soon simply be those
with a full tank of gas!!
Mike I.
> higher. Only some
> selling parts are
> Gordon Imports,
> confidently
> $0.99
> $29.95
> $29.95
> $29.95
> $25.95
> $0.90
> $0.90
> $25.00
> $25.00
> $3.90
> $3.25
> $1.10
> $110.59
> $9.90
> $29.90 $15.00
> $7.95
> $0.99
> $1.95
> $39.10
> $39.90
> $19.90
> $179.95
> $19.20
> $29.95
> $79.90
> $79.90
> $2.95
> $79.90
> $79.90
> $2.95
> $9.50
> $9.50
> $59.95
> $19.95
