13 maintenance locations?
Jon March
a common quote i see repeated regarding these cars is
"after operation in water, required greasing at 13 points, one of which required removal of the rear seat."
Is this true?
>>> What is the current maintenance-regeime to keep a car car in best shape?
(i think youre also supposed to dry your brakes with a long drive too?)
Jon March
i cant imagine driving a minimum of 45 miles each time i come out of the water!@#$
>> what are these "13 grease-points - one of which requires removal of the rear seat"
strandweiss62
All of them are mentioned in the user manual booklet.
Under the rear seat are two at the propeller shaft u-joints and after removing the two tunnel boots at the inner drive shaft u-joints.
Usually i drive only 25 miles after swimming. Most of the cars here are trailer queens, that is not so good. Some people here change wheel bearings every year.
Peter
