13 blade radiator fan?
markr132001
Wondering if anyone has attempted to install a Triumph plastic 13
blade fan to an amphicar. Curious if there is clearance and if there
is a benefit to hot running temps with the extra blades.
Sounds like a good idea. Do we have a volunteer?
Mark
Hello Mark,
I tried the 13 blade fan, with the Triumph fan clutch/water pump, and
found that it didn't work too well. I think the problem is that the
system was designed to work on a 1500 engine. That engine has a
larger pulley on the main shaft and spins the water pump faster than
it did with the smaller pulley on the Amphicar. It fits fine and just
might work with a large crank 1296 or 1500 engine, but not with the
1147 or small crank 1296.
White 67
Red 67
--- In amphicar-lovers@yahoogroups.com, "markr132001" <westlake5@c...>
> Mark
Mark Richardson Fan blade stud direction? General Amphicar Discussion 6
K backing plates, fan blade, radio General Amphicar Discussion 0
Jon March radiator cowl question General Amphicar Discussion 0
S Radiator Upgrade? General Amphicar Discussion 4
A Aliminum radiator info... General Amphicar Discussion 1
B SV: Electric Radiator Fan General Amphicar Discussion 3
G Electric Radiator Fan General Amphicar Discussion 1
J Radiator General Amphicar Discussion 9
A Radiator shrouds General Amphicar Discussion 4
W Radiator Performance General Amphicar Discussion 3
M RADIATOR OVERFLOW JUGS General Amphicar Discussion 2
L Radiator Hoses General Amphicar Discussion 0
A Radiator Top Seals General Amphicar Discussion 2
A Radiator Problem General Amphicar Discussion 14
A Radiator Mounts General Amphicar Discussion 0
A Radiator Mount General Amphicar Discussion 0
R Substitute for Radiator Mount General Amphicar Discussion 4
A Radiator Repair General Amphicar Discussion 6
E Radiator Marking Plate General Amphicar Discussion 0
B Radiator " Birthmark" ? General Amphicar Discussion 0
R Radiator Cap General Amphicar Discussion 0
T radiator rubber (buffer) mount substitute 9-30-38 General Amphicar Discussion 1
