1147 Oil pan w/ new oil pump
I have a question regarding putting a new oil pump in an 1147. It requires cutting away the oil pan baffle to clear the bigger pump and the pickup tube w/ the strainer attached. So much that there isnt much left of the baffle left. So my question is....Is there any problem with removing the whole baffle and grinding down the spot welds as if it was never there? The 1500's dont have any baffle, but does the 1147 need it? Thanks, Jack
amphicarian Spark Plug Choices for 1147 General Amphicar Discussion 4
amphicarian 1147 crank for sale? General Amphicar Discussion 1
B 1147 cc engine advice needed General Amphicar Discussion 2
M Triumph Engines 1147 General Amphicar Discussion 1
R 1147 motor General Amphicar Discussion 0
R 1147 rebuilt Triumph Spitfire long-block General Amphicar Discussion 0
M 1147 Engine General Amphicar Discussion 2
Latitude33 Bilge Pump outlet stainless steel tube General Amphicar Discussion 2
Jon March About the original bilge pump... General Amphicar Discussion 23
Jon March poll: original bilge pump mounting & depth gauge General Amphicar Discussion 1
okey0 Install of new bilge pump General Amphicar Discussion 3
Akamphi Bilge pump switch lamp General Amphicar Discussion 3
mike_israel Would a relay to bilge pump make sense General Amphicar Discussion 1
T Water pump General Amphicar Discussion 4
jfriese Bilge Pump Switch Lamp General Amphicar Discussion 2
H amphicar bilge pump General Amphicar Discussion 7
H Bilge Pump General Amphicar Discussion 0
sdreich Water Pump Slot for Grease? General Amphicar Discussion 4
S Backup bilge pump: plumbing and wiring General Amphicar Discussion 9
G windshield washer pump General Amphicar Discussion 10
D Water pump boom General Amphicar Discussion 1
M Looking for a water pump. General Amphicar Discussion 2
L fuel pump replacement General Amphicar Discussion 2
T fule pump replacement number General Amphicar Discussion 2
S Engine Stalls - Fuel Pump Question... General Amphicar Discussion 2
C where to get a water pump General Amphicar Discussion 0
A Water Pump Noise General Amphicar Discussion 0
A Original pump alternative General Amphicar Discussion 0
T read this Original pump alternative General Amphicar Discussion 1
R Fuel Pump rebuild kit General Amphicar Discussion 1
T So you like the look of your original bilge pump... General Amphicar Discussion 2
R Bildge Pump General Amphicar Discussion 1
R Water pump General Amphicar Discussion 6
D vacuum pump General Amphicar Discussion 1
